Close
User Tag List
Page 1 of 3 123 LastLast
Results 1 to 20 of 42
  1. #1
    Administrator PurdueGuy's Avatar
    Join Date
    Jan 2006
    Posts
    7,802
    Post Thanks / Like
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    PurdueGuy's '99 SC2 project car
    As-bought
    $1,000
    '99 SC2 - 3 door
    Gold exterior with stock spoiler
    Tan cloth interior
    No evidence of any bad wrecks, but some evidence of minor dings (spiderwebbed paint on rear bumper, etc).
    Stock alloy wheels
    Automatic transmission (no reverse)
    Non-ABS brakes
    AC
    Cruise
    Tape deck with EQ
    front speakers blown, rear speakers Sony junk
    Tan interior with some burn marks and tears in fabric (seats and headliner), not bad, but not great
    Carpet was "crunchy" from mildew, there apparently had been water in the car at some point, and there was evidence of broken glass, probably the passenger door window. Found a small hole in the passenger floorboard, apparently a drain hole for the water.
    Mod list:
    Mechanical/Drivetrain
    Automatic to manual transmission swap with welded differential pin ~$450 (winter '06-'07)
    2nd gen DOHC with SCAT rods, hyper pistons, and ported head (added mid '09)
    MOS short shifter with stock leather shift knob ~$45(summer '07)
    AEM CAI (added fall '07)
    SpeedRemedy all-aluminum radiator (added late '07)
    Groundpounder TAM (added 9/08 )
    Air compressor moisture filter catch can on PCV system (added ?)
    Exhaust
    Custom 2.5" mandrel bend exhaust system (added mid '09)
    91-92 header & downpipe (added mid '09)
    new flexpipe (added mid '09)
    extra O2 sensor bung (added mid '09)
    high flow cat (Magnaflow) (added mid '09)
    23" resonator (Magnaflow) (added mid '09)
    Thrush Turbo muffler (added mid '09)
    Stainless tip (added mid '09)
    Stock routing (added mid '09)
    Wheels & Tires
    15" Aftermarket split 6 spoke wheels (unsure of kind) [for daily driving] $50 (spring '07)
    Falken Ziex ZE-512 205/50/15 All-Season tires [for daily driving]
    Spun SPK-9 "Web" wheels, 16X7, 17.2lb, white [for autox] $325 (4/09)
    Braking
    Hawk front brake pads (added 5/08 )
    Rear disk swap (EverWear Gold pads)(added 5/08 )
    Goodridge stainless brake lines (added 5/08 )
    Suspension
    (Removed) E-bay front strut bar (added sometime in '07)
    AMR front strut bar (added 5/15 )
    Twistec rear strut bar (added 5/08 )
    H&R Sport lowering springs (added 5/08 )
    KYB Struts (added 5/08 )
    RPM 17.5mm adjustable rear swaybar and FunkyMonkey endlinks (added 5/08 )
    Rebuilt front suspension (winter '11-'12)
    - Control arms
    - Tie rod ends (Moog)
    - Wheel bearings
    - Hub
    - Sandblasted & Painted knuckles
    - Energy Suspension Poly bushings (sway bar)
    Audio
    Alpine head unit with CD / USB / Aux / Bluetooth / Microphone (added 5/15)
    Upgraded speakers - Sony XPlod rear 6.5" (added ?), salvage yard aftermarket front 6.5" speakers (added ?)
    Interior
    Overhead console with CD storage, sunglasses storage, operational Homelink, space for a couple aftermarket gauges, and map lights that function as the dome light (added fall '07)
    Passenger seat adjustable lumbar support (added summer '07)
    Rear view mirror with map lights (added sometime in '07)
    Leather steering wheel (stock) (added fall '07)
    Leather e-brake handle (stock) (added 9/08 )
    Full black interior swap (added 10/08 )
    Custom black headliner shaped to fit overhead console (added 11/08 )
    Custom black interior trim above beltline (added 11/08 )
    Custom shifter plate instead of shift boot (added fall '07)
    Exterior
    Clear corner lights (added sometime in '07)
    Corner light turn signal mod (added 9/08 ) - with amber LED corner light / turn signal bulb (added 5/15)
    Hidden antenna mod (added fall '08 )
  2. #2
    Join Date
    Jan 2006
    Posts
    7,802
    Post Thanks / Like
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Re: PurdueGuy's '99 SC2 project car
    Overhead console with CD storage, sunglasses storage, Homelink, and space for a couple aftermarket gauges:
    (taken from a late '90s Chevy Suburban)
    Still to do:
    -Redo the gray headliner fabric on the console. Same fabric will be used for the console as the headliner.
    -Get custom plate for the old HVAC controls hole, made to hold either 2 aftermarket gauges or a SAFC2 controller.
  3. #3
    Join Date
    Jan 2006
    Posts
    7,802
    Post Thanks / Like
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Started doing a black fabric wrap on the plastic trim above the beltline.
    1st piece done (trim piece on B-pillar part of 3rd door)
    Installed:
    Will redo the headliner as well, as soon as I get the LeSabre sun visors in.
    Headliner material:
    (black matches fabric on trim above, but headliner material has a lined pattern. Not as shiny as it looks in this pic)
  4. #4
    Join Date
    Jan 2006
    Posts
    7,802
    Post Thanks / Like
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    AEM CAI
    (engine bay's dirty - it's winter [img]{SMILIES_PATH}/icon_razz.gif[/img])
  5. #5
    Join Date
    Jan 2006
    Posts
    7,802
    Post Thanks / Like
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Rear View Mirror with Maplights:
    (taken from a Chevy Corsica)
  6. #6
    Join Date
    Jan 2006
    Posts
    7,802
    Post Thanks / Like
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Speed Remedy all-aluminum radiator
    (bought secondhand, no longer sold to my knowledge)
  7. #7
    Join Date
    Jan 2006
    Posts
    7,802
    Post Thanks / Like
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    The BOG (Box O' Goodies) arrived from Adam (ufppyro)!
    (ended up being Boxes of Goodies, but it's all good! )
    Rotors
    Brackets for rear strut bar
    H&R Sport springs on KYB GR-2 struts (a.k.a. my Peanutek suspension)
  8. #8
    Join Date
    Aug 2006
    Location
    Menomonee Falls WI
    Posts
    7,919
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    looking good, nice to see you finally drop some money on a car [img]{SMILIES_PATH}/smile.gif[/img] Keep us updated on the build progress.
  9. #9
    Join Date
    Jan 2006
    Posts
    7,802
    Post Thanks / Like
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by The Shaolin
    lol I dropped the money in the late fall/early winter, but stuff kept coming up for pyro and parts couldn't come off the car & get shipped til recently.
  10. #10
    Join Date
    Dec 2007
    Posts
    90
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I really like how you added the cd area with the gauges (have you put those in yet?)
    are you going to be keeping it the gold color, or changing it to black like the lining you put in.
    anyways, any more recent additions done to it?
    Gold, 97 SC2<br />[img]http&#58;//i264&#46;photobucket&#46;com/albums/ii173/Coloklute/quagmire&#46;gif[/img]<br /><br />my photobucket<br />(also has pics of Deutschland =D)<br />http://s287.photobucket.com/albums/ll128/Broder45/
  11. #11
    Join Date
    Dec 2007
    Posts
    90
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    also, I bought my 97 SC2 with 93k miles on it, good condition, scratches here and there, brand new tires, brand new brakes and ac system and new head unit for radio- got it for 4k, was that a good deal?
    and I dont have the third door [img]{SMILIES_PATH}/sad.gif[/img]
  12. #12
    Join Date
    Jan 2006
    Posts
    7,802
    Post Thanks / Like
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    no gauges yet, still waiting on the plate, and money to buy gauges. lol I may end up making a temporary filler plate out of plastic sometime, just to close the hole.
    I wouldn't have paid that much for a '97, but it'll probably still be a good car, so don't keep yourself awake at night over it. [img]{SMILIES_PATH}/wink.gif[/img]
  13. #13
    Join Date
    Jan 2006
    Posts
    7,802
    Post Thanks / Like
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Pics after installing the parts from the box o' goodies, plus rear disk swap:
  14. #14
    Join Date
    Jan 2006
    Posts
    7,802
    Post Thanks / Like
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Added:
    Groundpounder (need to pull it back out & press the bushing in better)
    floormats (got them & the e-brake handle for $6, they're better than the uber cheap floormats I had. lol)
    Also, pictures of stuff that was already on the car:
    Rear disk swap
    MOS short shifter (and a ghetto plate I made since my stock boot was junk and wouldn't fit with the shifter anyway)
  15. #15
    Join Date
    Jan 2006
    Posts
    7,802
    Post Thanks / Like
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Went to pick up a couple bolts at the junkyard yesterday, and low & behold, they had a '99 SC2 with black interior in the yard. Unfortunately, this yard is pretty pricey usually, so I wasn't sure it would be worth it to buy, but I went ahead & got it for about $265 with tax. Got:
    -front and rear seats
    -door panels (including 3rd door)
    -door trim
    -rear seat trim pieces
    -carpet
    -floormats
    -full dash assembly
    -rear deck cover
    The plan is to gut the SC2, then put in just the carpet, driver's seat, and dash at first. Then I will put in one piece at a time, and let the groundpounder tell me where the squeeks & rattles are, and try to reduce or eliminate most of them.
  16. #16
    Join Date
    Jan 2008
    Posts
    370
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    nice buy!
  17. #17
    Join Date
    Nov 2007
    Posts
    357
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I still hate you for having that black interior. I want to do it the hard way and re vinyl wrap everything. Except the seats... I might try to eventually do a leather conversion on the rear and do racing seats up front.
    -Follow the white Rabbitt-<br /><br />-&#39;98 SC2 DD<br />&quot;Rebecca&quot;<br />Minor cheap mods and SDA Tam and bones, rear disc conversion complete after minor failfest, manual swap on hold<br /><br />-&#39;07 VW Rabbit Wife&#39;s DD<br />The &quot;Blue Bunny&quot;<br />Completely stock with naked steelies<br /><br />-&#39;10 Harley Davidson XL883N<br />&quot;Gretchen&quot;<br />Takin it old school-
  18. #18
    Join Date
    Jan 2006
    Posts
    7,802
    Post Thanks / Like
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by polaris0352
    Well, as kind of a reply and an update:
    I've given up on doing the fabric wrap of the trim above the beltline. The pieces I had done had issues with glue letting loose (granted, it was the permatex stuff, not the good 3M stuff), fading (I didn't think to treat the fabric, so that might've been avoidable), and had had to make patches for some spots that I just couldn't stretch the fabric enough to get it to lay down (maybe could've remedied this by starting to lay the fabric from a different starting point, as well as choosing a more stretchy fabric).
    Instead I will be spraying those pieces in plastidip. I have already done the front cupholders and the driver's side door panel pull handle. It gives a nice grippy texture and looks great. On the door pull, it shut up all the cheap sounding, annoying squeeks that happened any time you pushed, pulled, grabbed the handle. I'm hoping the plastidip will get rid of some minor rattles from some other pieces as well.
    Door pull handle:
    I have re-done the headliner in the black fabric shown in one of the posts up further in this thread. It's not perfect, and I will likely redo it someday, but it is faaaaaar better than the saggy tan headliner that was in the car. I will be looking for an upholstery shop to redo my sun visors in the same fabric - that's a task I choose not to take on myself. I have dropped the project of putting LeSabre sun visors in my car, as while I was measuring and figuring out the alignment of the two mounting points this past week, I discovered a major downside of the slightly increased size of the visors - I couldn't turn them to the side window of the car without them smacking me in the face. lol I would have to lean waaay back, so sadly, they're just not practical. I may still keep an eye out for better visors to fit to the car as I go junkyarding (probably come spring), but for now I'm sticking with the stockers.
    I'll try to get the trim pieces done this week and get some pictures up. [img]{SMILIES_PATH}/smile.gif[/img]
  19. #19
    Join Date
    Aug 2006
    Location
    Menomonee Falls WI
    Posts
    7,919
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Plastidip looks awesome...any more info?
    You should be eliminating the rattles on the DD, the track car should THRIVE on rattles!
  20. #20
    Join Date
    Jan 2006
    Posts
    7,802
    Post Thanks / Like
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Plastidip thread
    Original plastidip thread on NASIOC
    Basically, you get the rattlecan plastidip, clean what you're gonna spray, and spray it. I did 6 layers on the handle for durability, on trim I'll rarely touch I'll only use 2 coats. The stuff is very forgiving and easy to get right.
    The SC2 is both my DD & track car. I do use the SC1 sometimes, but it's pretty much Em's car. Then I have the 'burban for a backup vehicle. Plus right now I have the '96 SL2 that's drivable, which actually has been functioning as my DD while I play with my interior. The '96 has a mildly built engine & 6-puck in it that will be pulled, tweeked, and put into the SC2 eventually - I just have to get a stock engine ready to put back into the SL2 to sell it. Way too nice of a car to just yank the engine out of & part out.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
