Close
User Tag List
Results 1 to 15 of 15
  1. #1
    rc423423r's Avatar
    Join Date
    Jun 2009
    Posts
    385
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Valve clearance deebs build.
    Sorry if this has been covered before, but I will be assembling an engine this weekend, and wanted to know if it would be necessary to clay the pistons or if I'm in the safe zone for valve clearance. More information can be found in my build thread.
    I have 3rd gen rods, .110" shaved engine pistons. (The top ringland was .220" before shaving). And a .005" head shave. I calculated it out that I will have about .020" piston protrusion. Running - American Custom Cams Stage 1: (IN .370 x 270/EX .340 x 260)
    For the more experienced engine builders out there do you think valve clearance will be an issue? Should I clay the pistons or is it a waste of time?
    Sent from my XT1096 using Tapatalk
  2. #2
    siris's Avatar
    Join Date
    Dec 2008
    Posts
    5,261
    Post Thanks / Like
    Mentioned
    27 Post(s)
    Tagged
    1 Thread(s)
    If you have the time and means, I would. Especially if you have changed the cam timing. It won't hurt anything.
  3. Likes ZombieSatty liked this post
  4. #3
    Approved Vendor ZombieSatty's Avatar
    Join Date
    Feb 2007
    Location
    Omaha, NE
    Posts
    6,381
    Post Thanks / Like
    Blog Entries
    2
    Mentioned
    13 Post(s)
    Tagged
    0 Thread(s)
    Interested in responses and or results.
  5. #4
    rc423423r's Avatar
    Join Date
    Jun 2009
    Posts
    385
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Would I be able to reuse the head gasket if I clayed it?
  6. #5
    Join Date
    Dec 2006
    Posts
    3,947
    Post Thanks / Like
    Mentioned
    8 Post(s)
    Tagged
    0 Thread(s)
    no. But you could ask one of us hoarders to send you a used one.
  7. #6
    rc423423r's Avatar
    Join Date
    Jun 2009
    Posts
    385
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hmm okay we probably have a used one lying around.
  8. #7
    siris's Avatar
    Join Date
    Dec 2008
    Posts
    5,261
    Post Thanks / Like
    Mentioned
    27 Post(s)
    Tagged
    1 Thread(s)
    Clay it without the HG. Cut the clay and measure the thin spots. If it clears without the HG you are more than good.
  9. #8
    rc423423r's Avatar
    Join Date
    Jun 2009
    Posts
    385
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Ok that sounds like a plan...I'm thinking it should be okay, because I've heard of guys cutting like .040" off the head with much more aggressive cams. Also stock protrusion is like .0118 with a .0149 service limit. According to this I guess I'm worried because I didn't get valve reliefs cut into these pistons because I wanted to keep compression high.
    It's looking like I'll have to clay the pistons after all unless anyone else chimes in with Indisputable evidence lol
  10. #9
    6S Moderator S.Bretz's Avatar
    Join Date
    Apr 2004
    Location
    Lutz, Fl
    Posts
    15,176
    Post Thanks / Like
    Mentioned
    27 Post(s)
    Tagged
    0 Thread(s)
    I wouldnt even bother...you will be okay as long as the cams are time properly.
    To be honest i dont know why they put valve releifs in. The valves are nowhere near close if the cams are timed properly.
  11. #10
    rc423423r's Avatar
    Join Date
    Jun 2009
    Posts
    385
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Okay thanks man, I'm pretty sure I've heard of much more extreme builds on here without issue. I'll keep you guys posted in my build thread. In case things go boom
  12. #11
    saturnspeed_12's Avatar
    Join Date
    Nov 2005
    Location
    Urbana, OH
    Posts
    2,993
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    What year vehicle are the pistons intended for you bought? Reason I ask is because your pistons are completely smooth, whereas mine have a very slight indentation still in the middle. I took off the minimal amount I could. I have 01 rods and 92 pistons with flat faced valves. I slapped mine together and have put at least 40k on it. I also am running twin intake cams. I wish I could remember my protrusion, but I thought it was something ridiculous like .040-.045". I also had my head resurfaced recently as it was warped .004".
    The only issue I have been having is timing, not mechanical. I am pretty sure the pcm keeps pulling time, whether just noise to the knock or if I'm actually getting ping/detonation. But I am also a bit on edge for fuel knowing I'm still stock running 93. Even tuned, I still think I need slightly higher octane.
    That is mine just a week ago. I had low compression in two cylinders from my head being warped, so I had to tear it apart.
    2017 Nissan Frontier-4WD home improvement hauler
  13. #12
    rc423423r's Avatar
    Join Date
    Jun 2009
    Posts
    385
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    They are 2nd gen pistons. When you say indentation are you talking about the valve reliefs? Because mine are still there but barely visible. What compression ratio are you running with that much protrusion? Because I calculated I should be around 11:1
  14. #13
    rc423423r's Avatar
    Join Date
    Jun 2009
    Posts
    385
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    http://sixthsphere.com/archive/index.php/t-59197.html
    This is the link I was basing my calculations off of
  15. #14
    Join Date
    Nov 2005
    Location
    Urbana, OH
    Posts
    2,993
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Okay, that is what I was thinking. Mine are the earlier ones, which had larger upper ring land. But if you see my pistons have an indentation in the center of it. That was due to the flat faced valves used in early heads. When the concaved valves were used, that indentation was removed. It was for compression ratio.
    There was another article on this same thing that I used when building my engine. I took the information and didn't calculate mine. I just can only make a guess, and with the numbers I was using from the article I used (before building), it looked to be like 12:1 or more. The one thing I know, but still wish I actually wrote down, was the protrusion since I just measured it last week. I had to use two feelers to find the gap, so I know it is at least .035". I just made the mistake of taking the information, using minimal clearance, and went wild with the build. Had it all balanced to 8k, and was amped to get it together. So my true compression ratio isn't fully known. My cylinder pressures are 250psi on a very cold engine, that I truly know. lol
  16. #15
    Join Date
    Jul 2015
    Location
    N.E. Oklahoma
    Posts
    401
    Post Thanks / Like
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    You need some long tube headers. I was looking to do an high comp build and I looked to Mazda for inspiration and tech ideas as to how they mitigate detonation on their new skyactive motors. These motors run 14:1 and higher comps on some models. On the fuel side they are using 2 injectors per cyl. one on the intake runner to cool the charge and then another spritz via direct inj. to cool the charge on compression. On the exhaust side they play with valve timing and speeds with the cams, which unless your running an older head with custom ground cam and adjustable gear, we're limited. The exhaust manifolds are another area they prevent ping by running long tube headers that have more room per runner than exhaust gas expelled. This and the fact they prevent a pulse pushing ex gas back into another cylinder keeps chamber temps down. That also helps keep away from the ping. We've also discovered through rigorous googling and math that Mazda bp pistons on 1st gen rods will work in our motors for high comp builds. you just have to replace the bushing in the small end of the rods to accept the pin from those pistons, which any engine shop should do for about 40 bucks. They are a stronger piston and better designed than ours, especially since you've had to get rid of so much of the top land with the machining. I think that bill gude offers it a package for 400. but you can get away with doing it in house for much less. His math also puts the comp at I think 13.5:1 but he machines some off the top to bring it to 12:1. Also they have valve relief in them so then you just have to worry about slap, also why he takes some off the top and land I think.
  17. Likes ZombieSatty liked this post
Posting Permissions
  • You may not post replies
  • You may not edit your posts
