Close
User Tag List
Results 1 to 7 of 7
  1. #1
    Lord Freely's Avatar
    Join Date
    May 2017
    Posts
    27
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Can some one give me some info on how to fix my sunroof? I drive a '02 SC2.
    I believe the motor may be broken, the glass and trim are fine. I will update with some photos soon. Any help would be appreciated, thanks!
    Sent from my HTC 10 using Tapatalk
  2. #2
    HNIC SC2Sick's Avatar
    Join Date
    Nov 2004
    Location
    St. Paul, Minnesota
    Posts
    11,096
    Post Thanks / Like
    Blog Entries
    4
    Mentioned
    39 Post(s)
    Tagged
    0 Thread(s)
    2003 BMW e46
    2001 Saturn SC2 - Forged with everything but boost - FOR SALE PM FOR MORE INFO
    1998 Ford Ranger
  3. #3
    Join Date
    May 2017
    Posts
    27
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thank you, I appreciate the help.
  4. #4
    toka100's Avatar
    Join Date
    Nov 2008
    Location
    North Platte NE
    Posts
    864
    Post Thanks / Like
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Wish he did that for 1gen cars.
  5. #5
    trottida's Avatar
    Join Date
    Aug 2014
    Location
    Northern Ontario, Canada
    Posts
    182
    Post Thanks / Like
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Lord Freely View Post
    If you're positive that it is the motor they are easy to replace. The gears will strip and the motor will make a repetitive clicking noise. Remove headliner, undo 3 bolts and a couple of connectors and it's out. When you have the headliner off you can manually crank the sunroof with a large slotted screwdriver to test that the tracks work as intended. You'll see the slot circled in red on the photo below, insert screwdriver, press in and turn. If the track slides are shot then the roof will not open smoothly if at all.
    Current
    1999 SL2 MT (256K km, 10-2016 to present)
    2001 SL1 MT (415K km, 10-2008 to present)
    Past
    1993 SW2 AT (03-2000 to 04-2010)
    2001 LW200 MT (06-2001 to 01-2005)
    1992 SL2 MT (06-1992 to 09-1997)
  6. #6
    punkboySL2's Avatar
    Join Date
    Jan 2006
    Location
    AUSTIN, TX
    Posts
    8,623
    Post Thanks / Like
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    What is it doing or not doing? I know mine is finicky, but it is the main relay/module and the issue is the that the circuit board won't stay planted where it is supposed to stay.
  7. #7
    Join Date
    May 2017
    Posts
    27
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by punkboySL2 View Post
    When I use the switch nothing happens at all. I'm sure it is the electrical stuff. I hope it isn't anything major.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
