Close
User Tag List
Results 1 to 12 of 12
  1. #1
    ajs_saturn's Avatar
    Join Date
    Mar 2014
    Location
    Corpus Christi, TX
    Posts
    310
    Post Thanks / Like
    Blog Entries
    1
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Slimming Down the Stock Engine Wire Harness (Running on Megasquirt)
    While my car is on jack stands, I decided to clean up some wiring mainly on the OEM engine harness. I'm basically only keeping connectors that work the instrument cluster gauges and idiot lights such as:
    1. B/U switch
    2. VSS
    3. CPS
    4. ECTS
    5. Oil Pressure
    6. Alternator Voltage
    7. Cooling Fan
    I have a question on a few connectors on whether I should keep them or snip them:
    1. Fuel Vapor Canister Purge Solenoid: How important is this one? I know it releases vapor, which seems important, so I'm thinking about keeping it, but has anyone deleted this?
    2. Both O2 sensors: These I'm pretty sure I can get rid of, I have a separate WBO2 already and I doubt they're for much more than emissions.
    3. Knock sensor: I think I can delete this too. I don't know what it does other than detect a knock and readjust timing to correct it, but I'll be running timing off of MS anyway.
    -2007 Sky Redline 5spd 01/18 - present
    -2001 SL1 5spd. 02/14 - 12/17 (cracked ringland from boost, parted and scrapped)
    -2001 SC1 5spd. 04/15 - 11/16 (daily, meh)
    -2000 SL 5spd. 04/05 - 06/10 (the rice ho that started it all)
  2. #2
    ajs_saturn's Avatar
    Join Date
    Mar 2014
    Location
    Corpus Christi, TX
    Posts
    310
    Post Thanks / Like
    Blog Entries
    1
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Did some more research...
    1. Getting rid of the purge solenoid completely. I'll just vent the line on the tank side and cap the line on the IM side.
    2. Getting rid of O2 sensors. Don't need them and I'll use bank 1 for my EGT that I'll be installing.
    3. No need for the knock sensor for obvious reasons.
    That will leave just the above listed sensors for instrument cluster informational purposes. Once I've thinned down the harness I will merge it with my MS harness to make only 1 main loom going through the engine bay.
  3. Likes ZombieSatty liked this post
  4. #3
    Approved Vendor ZombieSatty's Avatar
    Join Date
    Feb 2007
    Location
    Omaha, NE
    Posts
    6,343
    Post Thanks / Like
    Blog Entries
    2
    Mentioned
    13 Post(s)
    Tagged
    0 Thread(s)
    Nice! I hate the idea of the dual harnesses that seem the norm with MS. I understand while getting it set up, but after that, snip snip.
    Sent from my SM-G930P using Tapatalk
  5. #4
    ajs_saturn's Avatar
    Join Date
    Mar 2014
    Location
    Corpus Christi, TX
    Posts
    310
    Post Thanks / Like
    Blog Entries
    1
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    My initial set up was like that for redundancy. Now I'm changing so much that redundancy is impossible with just a wire harness swap. It should wind up pretty clean when I'm done!
  6. Likes ZombieSatty liked this post
  7. #5
    ajs_saturn's Avatar
    Join Date
    Mar 2014
    Location
    Corpus Christi, TX
    Posts
    310
    Post Thanks / Like
    Blog Entries
    1
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    This is what's left after de-pinning the excess junk!
    Wire management is going to be so nice!
  8. Likes ZombieSatty, importsdontlikeme liked this post
  9. #6
    Resident Electromotive Expert importsdontlikeme's Avatar
    Join Date
    Feb 2010
    Location
    Westminster, Maryland
    Posts
    3,022
    Post Thanks / Like
    Blog Entries
    3
    Mentioned
    28 Post(s)
    Tagged
    0 Thread(s)
    Does MS have a knock input? If it does you should take advantage of it.
    On every install I've done I always run the knock sensor into the new ECU. It's especially useful for data logging.
    Sent from my iPhone using Tapatalk Pro
  10. #7
    ajs_saturn's Avatar
    Join Date
    Mar 2014
    Location
    Corpus Christi, TX
    Posts
    310
    Post Thanks / Like
    Blog Entries
    1
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by importsdontlikeme View Post
    I think you can add it into the daughter board. Doesn't come on the standard MS though. I agree it could be useful though, especially with timing.
  11. #8
    ajs_saturn's Avatar
    Join Date
    Mar 2014
    Location
    Corpus Christi, TX
    Posts
    310
    Post Thanks / Like
    Blog Entries
    1
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
  12. #9
    Join Date
    Feb 2007
    Location
    Omaha, NE
    Posts
    6,343
    Post Thanks / Like
    Blog Entries
    2
    Mentioned
    13 Post(s)
    Tagged
    0 Thread(s)
    See and people shushed me for wanting to ditch the stock pcm...
  13. #10
    ajs_saturn's Avatar
    Join Date
    Mar 2014
    Location
    Corpus Christi, TX
    Posts
    310
    Post Thanks / Like
    Blog Entries
    1
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    They're probably using toggle switches for the rad fan and aftermarket gauges for Speedo, tach and oil pressure.
  14. #11
    Join Date
    Feb 2010
    Location
    Posts
    3,022
    Post Thanks / Like
    Blog Entries
    3
    Mentioned
    28 Post(s)
    Tagged
    0 Thread(s)
    I'm pretty sure the speedo is the only one powered by the PCM.
    MS should have a tach output. And GPO's (a fan output)?
  15. #12
    ajs_saturn's Avatar
    Join Date
    Mar 2014
    Location
    Corpus Christi, TX
    Posts
    310
    Post Thanks / Like
    Blog Entries
    1
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Yes, I believe you're right. I just choose to used the stock junk. I'm installing a rad fan bypass switch anyway.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
