Close
User Tag List
Results 1 to 7 of 7
  1. #1
    rc423423r's Avatar
    Join Date
    Jun 2009
    Posts
    385
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Piston rings without pulling engine
    So I just built this motor about 6k miles ago, you can see the whole process in my build thread. The car recently stopped on me on the highway. There is smoke coming out of the dipstick tube, and exhaust, and the spark plug was oily. This means i did some damage which was probably a result of sucking water through my CAI a couple weeks ago. So i imagine my piston rings are trash on that cylinder, there's no way 'its my valve seals because the head is brand new.
    my question is can i re-ring the piston (piston 4) without pulling the engine, and without sending the block back to the machine shop, because it was just bored .040 over when i built it 6k miles ago. Im thinking i should be able to get away with a hone only? what do you guys think?
    Normally i would just pull the engine, however if i could do it in the car that would be much easier for me working alone.
  2. #2
    Join Date
    Feb 2016
    Posts
    250
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I did mine 3 years ago. I did everything except main bearings. I left the transmission in also which made it a little harder but it can be done. If you smoked your ring I would be leary with just a hone. It might be fine but I would mic it and go from there. My 2 cents.
    Sent from my SAMSUNG-SM-G900A using Tapatalk
  3. #3
    rc423423r's Avatar
    Join Date
    Jun 2009
    Posts
    385
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by axxer4200 View Post
    Yeah that makes sense, i've seen my dad re-ring an engine we built once that didn't seal properly without taking it out of the car and have it run fine after. I suspect their shouldn't be too much wear on the cylinder walls but there's always a chance they could be out of round.
  4. Likes axxer4200 liked this post
  5. #4
    Join Date
    Nov 2007
    Location
    Innisfil, ON
    Posts
    2,031
    Post Thanks / Like
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    You can do it in frame for sure... but for the effort it takes getting the tcc and pan sealed up nicely why not just pull it and do it properly?
    http://our6thplanet.com/
    40 something saturns.. oh who fraking counts anymore
  6. #5
    rc423423r's Avatar
    Join Date
    Jun 2009
    Posts
    385
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by andrew88 View Post
    Well I will be doing it on a lift, so I figured it wouldn't be too hard getting the pan and tcc on. I've done a tcc before and it took some patience but wasn't too bad.
    Sent from my SM-J727V using Tapatalk
  7. Likes axxer4200 liked this post
  8. #6
    punkboySL2's Avatar
    Join Date
    Jan 2006
    Location
    AUSTIN, TX
    Posts
    8,624
    Post Thanks / Like
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Why don't you disconnect the front subframe and raise the rest of the car on the lift, then you can easily do it all out of the car. No need for a hoist.
  9. Likes axxer4200 liked this post
  10. #7
    6S Moderator S.Bretz's Avatar
    Join Date
    Apr 2004
    Location
    Lutz, Fl
    Posts
    15,226
    Post Thanks / Like
    Mentioned
    27 Post(s)
    Tagged
    0 Thread(s)
    If you have a lift its not bad...but in a driveway its easier to pull the engine and get it on a stand.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
