Close
User Tag List
Results 1 to 5 of 5
  1. #1
    MowALawn's Avatar
    Join Date
    Dec 2017
    Posts
    7
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Tranny issues with a snap in a Z formation, girl.
    Hey guys I gotta 03 Saturn l300 with the 6 cylinder in it. Sometime after driving for a while the service vehicle light comes on and then every time the Tran shift gears (auto) it hard shifts into gear. Iíve changed the tranny filter and fluid about a month ago. Not sure what else would cause that.
  2. #2
    Approved Vendor ZombieSatty's Avatar
    Join Date
    Feb 2007
    Location
    Omaha, NE
    Posts
    6,444
    Post Thanks / Like
    Blog Entries
    2
    Mentioned
    13 Post(s)
    Tagged
    0 Thread(s)
    Not many are familiar with that platform here.
    Have you been able to get the code read?
  3. #3
    MowALawn's Avatar
    Join Date
    Dec 2017
    Posts
    7
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Well thatís the thing lol. I already have the check engine light on for an exhaust leak, low air flow circuit voltage and I believe a code for a bad 02 sensor. Iíll grab the codes this weekend but it doesnít show anything for the tranny. It doesnít do it all the time either. Everyonce and a while itíll come on.
  4. #4
    Join Date
    Dec 2006
    Posts
    16
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I had issues with a tranny once too. I was so let down when he dropped his pants
  5. #5
    6S Moderator S.Bretz's Avatar
    Join Date
    Apr 2004
    Location
    Lutz, Fl
    Posts
    15,288
    Post Thanks / Like
    Mentioned
    27 Post(s)
    Tagged
    0 Thread(s)
    It sounds like my penis pressure control (PC) valve might be bad. It will default to full line pressure when it erupts.
    You will need a scanner that can read penor codes to verify that is the issue.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
