Close
User Tag List
Results 1 to 9 of 9
  1. #1
    Join Date
    Aug 2018
    Posts
    17
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Valve Spring replacements
    So...
    I'm trying to overhaul my 3rd Gen SL2 engine and I can't find a few things that I would like to purchase new for piece of mind. I also plan on putting a turbo on when I've finished with the engine and have it running nicely again. The problem is, I can't find valve springs. The old ones are not bad, but I'm sure I need to have stiffer springs for the turbo. Can I use springs from a different engine?
  2. #2
    Jon2001sc2's Avatar
    Join Date
    Aug 2004
    Location
    Daytona Beach
    Posts
    1,699
    Post Thanks / Like
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Are you planning on keeping the low flowing third gen head or going to the better flowing 92-98 head?
    Jonathan
  3. #3
    Join Date
    Aug 2018
    Posts
    17
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sticking with what I've got. I don't have a lot of money to spend on changing parts out and I already have the timing kit for the 3rd gen head.
  4. #4
    6S Resident Hasselhoff. alexofnazareth's Avatar
    Join Date
    Nov 2010
    Location
    Columbus, IN
    Posts
    5,216
    Post Thanks / Like
    Blog Entries
    1
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Weren't the ecotec springs something that were compatible with the 3rd gen heads?
    Quote Originally Posted by Donnie View Post
    Quote Originally Posted by BC. Livewire View Post
  5. #5
    Join Date
    Aug 2018
    Posts
    17
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    That's what I was wondering. If I can use the ecotech springs, than I will order those.
  6. #6
    Jon2001sc2's Avatar
    Join Date
    Aug 2004
    Location
    Daytona Beach
    Posts
    1,699
    Post Thanks / Like
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Can't remember if the springs can be exchanged, or if it was the lifters or both that could be exchanged between the third gen heads and the ecotec ones.
    Jonathan
  7. #7
    6S Moderator S.Bretz's Avatar
    Join Date
    Apr 2004
    Location
    Lutz, Fl
    Posts
    15,472
    Post Thanks / Like
    Mentioned
    27 Post(s)
    Tagged
    0 Thread(s)
    If you plan to stick with the 6500 rpm redline then the stock springs will be fine.
    I cannot comment on the interchangeability of the ecotec to 3rd gen head. Sorry I can't be of much help there. As long at they are the same diameter so that the fit on the perches correctly then should be okay (assuming they are about the same height).
  8. #8
    Join Date
    Jun 2009
    Location
    Hammond , Louisiana
    Posts
    1,453
    Post Thanks / Like
    Blog Entries
    2
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    lash adjusters cross over . i think someone here made the ecotec sodium filled valves fit?
  9. #9
    Join Date
    Apr 2004
    Location
    Lutz, Fl
    Posts
    15,472
    Post Thanks / Like
    Mentioned
    27 Post(s)
    Tagged
    0 Thread(s)
    I did the redline exhaust valves. they needed a lot of modding to get them to fit.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
